Replacing screen with a genuine apple screen
I was wondering if i brought a genuine apple screen used from another iphone 11 to repair a broken iphone. Will this still display there ‘can’t verify genuine screen message in settings?’
Hello Jake - as mentioned above, the iPhones display is paired to the motherboard, amongst other components, such as the screen, battery, vibrator, FaceID. If you replace the screen it will display the ‘unable to verify that this iPhone has a genuine display message’, as each screen is electronically paired (every major part of an iPhone has its own serial number). There is ways of reprogramming the screen using products for example like JC (Hugh Jeffreys has a video on YouTube about them), however they usually cost $100-200+ for the reprogrammer.
I would recommend that you just ignore the message. From what I have seen online it only really pops up when it has been reset, or on settings; and other than disabling True Tone should function fine. OEM screens appear to be the best choice, and as it is LCD they aren’t usually too much more than high quality aftermarket screens.
You could also consider paying a company that has the skills and equipment to do a glass only screen refurbishment - where they use the original LCD panel and only replace the glass - this is a hard job and will cost a fair bit but should avoid the message, and you will have an original LCD panel?
Hope this helps!
这个答案有帮助吗?
hello Jake,
iphone 11 has an electronically linked screen, as does the battery on the XR / XS / XS-Max models. Only a visit to an Apple authorized service center will help. Yes, there is a method of cheating the system and installing even a non-genuine screen, but I consider it a quack method and I do not recommend it due to the high risk of damaging the screen.
这个答案有帮助吗?
The only way to remove the message, is to transfer the IC chip that is attached to the digiter flex cable.
This is what contains the serialisation.
The machine mentioned, only transfers true tone.
Some versions of IOS may ignore the screen not genuine.
If you know a microsolderer, they would be able to swap the IC chip.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 68
总计 858
