跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
Face ID and phone restarting
My 11 pro Max phone is restarting every 3 mints water it got damage by liquid and Face ID is not working except tht 2 everything is working good
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Did you eventually fix your problem??
完成的
添加一条评论
2个答案
已选择的解决方案
The first thing to try would be a battery replacement followed by the dock connector. These are the main two reasons the phone would restart every few minutes.
这个答案有帮助吗?
得分 1
添加一条评论
I have had a iPhone 7 Plus in the past that had water damage and a similar problem of frequently shutting off and the home button not working. I would recommend fully shutting down the iPhone, removing the SIM card tray, and leaving it in an open air environment to dry out for about a week or two. This usually dries out the components and I was able to get the iPhone to stop restarting and get the home button working again. You could try to blow dry the phone on a low heat setting, but this should be a last resort. Rice and silica packs do not work very well for liquid damage.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sanjay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 801
