跳转到主内容
更大尺寸的 Nintendo DSi,北美市场于2010年3月开售。大多数维修只需要一个螺丝刀和塑料撬具即可完成。
dsi xl charge port ripped pads
so i tried to repair my dsi xl because it had a bad charge port, and i had bought a replacement charge port but when i went to try and take out the faulty charge port, i had ripped 4 pads out if the motherboard. the pads where the 4 pads all next to each other. and yes i have solder experience but this was my first time replacing the port
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi, sorry i come almost three years after the "war". Don’t worry about judgment here, all the people who try to change a port of a ds know the complexity of changing it (and I’m not saying that because I’ve already changed at least 30 ports and I still sometimes brought pads!^^ ). There is still a way to save this motherboard, if in the three years she was not finished in the trash or in donor board, just put a "'jumper wire" you have to solder to the part of the port that no longer have a pad, follow the line of the pcb and remove the green protect on the pcb to be able to solder the cable and do it for the four, here is a video that will explain better than me and shows how to do (not on a ds but that explain the process) https://www.youtube.com/watch?v=AR0lb7YI...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eduardo Bustamante 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 148
