跳转到主内容
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz dual-core i5 processor. Released June 2017.
What is the wifi card model?
wifi is not working, I tried to reinstall Os, still same. so if I want to change the wifi card what will be the wifi card model?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Here’s the guide to get to it: iMac Intel 21.5" EMC 3068 Airport/Bluetooth Card Replacement Presently this part is hard to find! iMac 21.5"/27" Airport/Bluetooth Card Apple P/N 661-07505 you’ll also need the heat transfer putty.
Are you sure that’s the problem? This is a custom part made by BroadCom for Apple.
I would do a bit more diagnostics before opening the system. Are you able to see the WiFi hardware under the System Report? What do you see in the menu when you press the Option key when you click on the WiFi icon on the menu? Take a snapshot of the grey area and past it here for us to see 在已经存在的问题里加入图片.
If the system was already opened then it maybe the antenna plates got damaged as they are just behind the display glass.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
iMac Intel 21.5" EMC 3068 Airport/Bluetooth Card图片
指南
难度:
中等
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shamveel Ek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 161
