跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
The memory I purchased does not work very well.
The memory I purchased does not work very good. Neither one works alone or in tandem. The only way they work is if I use one of them with the Apple memory that came with the iMac in one of the slots. I mixed and matched several times so it’s not like I’m seating them incorrectly.
So instead of 4gig with the two I bought, I can only get 3gig.
Thank you
John Coffey
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Depending on your exact model as well as your OS-X version 3 GB maybe the limit!
The White iMac’s need to be running the OS X 10.7.5 and you needed a firmare update. Its been awhile and I don’t know which one was the needed version.
Locate your exact system here EveryMac - Lookup plugging in your systems S/N. Then tell us which is yours.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
SV In Like Flynn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 26
