跳转到主内容
加入维修社区 - 创建账户
The Maytag Washer model MVWB765FW is a top-load washing machine with a deep fill option. The washer has a volume of 4.7 cubic feet.
Stops mid spin won't drain/burning smell
I have bought new parts replacing the old the pump, and the belts underneath. Both these parts are brand new. The machine will fill with water and will agitate, but when it comes time to spin full speed and drain the water the machine will start spinning, then right before getting to full speed it will click, and stop all movement. No water will drain out during this process. Brand new pump though, and hoses are not clogged. Burning smell after it clicks, and stops spinning. Must unplug machine every time or it won’t do anything else. it is a belt driven pump. Is this a malfunctioning motor?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
The model number provided is not accurate for a belt driven pump! Please update.
完成的
Model number LA512
完成的
添加一条评论
1个答案
最有帮助的答案
Are the springs that hold tension on the tub/agitate belt intact? Also does the motor move freely on the tensioning track? I put a new belt on mine a year or so ago and it smelled a bit and squeeled for a few loads after that belt replacement but it finally stopped giving those symptoms after a few loads.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jake 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,171
