跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Screen auto typing and opening closing apps
Hi,
Changed the screen on an iPhone 8. When turned phone on for the first time it was fine, only thing was screen was very dull with a yellow tint. Cleaned up the connectors on logic board and turned phone on again. brightness was good, then after a while screen started playing up. During boot and iphone logo there is a tint (Line) the height of the apple logo in the middle of the screen. The tint runs from the left of the screen to the right exactly through the startup logo. It is like a shadow Then phone turn on normally with no line. Then starts playing up.
New screen ghost types and opens and closes apps.
Checked the screen connectors on the logic board. Cleaned them up with 99% Isopropyl Alcohol, checked for pin damage under microscope and logic board damage. Found none. Checked the logic board for missing caps or filters. Found none. Check flex cables on screen they look fine.
What could the issue be?
I have ordered another screen to check if its just a faulty digitizer on the new screen. But I wanted to ask if anyone has had issues with it being the U3600? and if the U3600 is changeable or is it locked to the logic board?
Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You should replace the screen because it is probably damaged.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tommy Duris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 56
