跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1700 个问题 查看全部
Faulty disk drive and su-42118-6 error
I have inherited a faulty PS4 for free as my friend said it was “mildly broken” after he opened it up to clean it and put it back together.
The issues are :
  • disk drive doesn’t take disks, the disc won’t go in, I have opened up PS4 and no immediate problems or blockages that I can see
  • I get error su-42118-6 when I try and update the PS4. I have tried to install the file from USB in Safe Mode and get same issue.
Am I to assume both of these issues are interconnected? Any suggestions? Should I just replace the disk drive?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
This su-42118-6 error comes from a broken ribbon connector between your motherboard and BD-ROM. When this happens, the system won't be able to communicate with the BD-ROM. To fix it, investigate the BD-ROM ribbon connection between the drive and motherboard.
You can check if the PS4 works correctly after you fixed the ribbon connector issue.
Otherwise kindly check out the method in the post below.
https://www.minitool.com/news/ps4-firmwa...
这个答案有帮助吗?
得分 2
添加一条评论
If it's regular console check the main cable going from the disc drive to the mother board close to the power supply connection if cable is bad replace and it will work.
If it is slim there is some fuse you have to replace f6201 or f6202
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LeilaY 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 50
总计 8,522
