跳转到主内容
The Black and Decker AS150 Steam Advantage Iron is a white and aqua hand-held iron with pivotal cord.
Leaking water from bottom whether is on and off
Black and Decker house iron , leaking water from bottom whether is on or off when up right positions when not using ( maybe crack internally/water tank/water system)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Hi @charlieccc ,
What is the model number of the iron?
You may have to dis-assemble it to see where the leak is and whether or not it can be easily repaired. For example it may be a faulty gasket rather than a split in the tank
这个答案有帮助吗?
得分 3
3条评论:
Thank you Jayeff!
完成的
Sometimes you cannot get a gasket. High temp RTV could be very helpful.
完成的
how to repair it.please upload video.
完成的
添加一条评论
添加你的答案
Charlie Charlie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 37
总计 2,544
