Can the iPhone 4s camera be installed in the iPhone 4?
Just as the tittle says.
Can the camera be installed on the iPhone 4 to "upgrade" the camera?
这是一个好问题吗?
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
声誉积分: 1
Just as we expected, the connector for the camera on the iPhone 4S is different than the connector on the iPhone 4 (CDMA and GSM). This means that you cannot "upgrade" your camera in your iPhone 4 (or downgrade your 4S if for some odd reason you can't handle the 8 megapixel camera). The iPhone 4S connector has more pins. Even if it did fit, I don't think it would work anyways.
iPhone 4S:
iPhone 4 (CDMA and GSM Side-By-Side):
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 3,142
I think it will be different since they changed it quite a bit. We'll check that out when we do our teardown.
由 Scott Head 完成的
agreed, too early to tell. from what I know about apple components, most likely not.
由 hectordtruong 完成的
Do you know who the manufuacturer of the camera is? The world is waiting...
由 bob cooper 完成的
