跳转到主内容
Satellite radios, either portable or vehicle-mounted, allow you to listen to XM or Sirius satellite radio from anywhere on Earth.
22 个问题 查看全部
Docking station works fine in one building,
Two buildings 20 yards apart. Two radios with docking stations work fine in bldg. A, neither one works in bldg. B. Both buildings have outdoor antenna with same view of the sky. LCD display shows station, artist and song title but no audio. Radio in bldg. B worked for about 5 years then quit. Replaced antenna and wiring in bldg. B still not working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @mcjimbo ,
Don't know the system that you're describing but are the docking stations fixed to the radio or are they fixed in the building and the radio can be removed so to speak?
If fixed in the building, just wondering if you can swap the docking stations to eliminate it as a possible cause.
完成的
添加一条评论
1个答案
Turns out the problem is with the power unit. It is a switching adapter that powers the speakers along with the radio function. Not sure exactly how it works but it can power the unit without powering the speakers. I have a new one on order, will update when it is received.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jimbo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 33
