跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
No light on magsafe
Hi,
I recently refubrished a macbook and broke the sleep sensor flex cable, I replaced it with a new one.
The problem now is that after that manoeuver the magsafe light is non existent, and the battery shows “connected but not charging”.
Appart from that the computer works fine, I attempted a SMC reset to no avail.
I opened the computer and used a multimeter, the 1 volt wire is working fine and everything gets seems to get power.
I replaced the DC-in board with a new one aswell
What could be the issue ? is it the sleep sensor from ebay ? It worked fine before I opened it to change the thermal paste and since that it’s impossible to charge my battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sadly, if replacing the DC-In board and replacing the sleep sensor cable which you damaged didn’t fix things then you have a logic board issue!
You talk about refreshing the thermal paste in the process did you manage to damage the logic board SMC logic?
At this point I would take the logic board fully out and compare it to the iFixit guide images look for a missing or damaged component. If you don’t find anything then the charging logic its self is damaged, you’ll need to get a new logic board at that point unless you know someone with the deeper skills to fix your logic board.
这个答案有帮助吗?
得分 0
添加一条评论
As @danj said, it could be logic board damage. However, it could potentially also be a bad charger/MagSafe connection. Try giving the charger connector a clean on both the laptop and the charger. Also try wiggling the MagSafe charger for the first second of it being plugged in. It’s not too likely, but that might be the culprit. I do have one question though, does the MagSafe light show a very dim green in an unlit room?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Irodas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 133
