跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
Intermittent digitiser after replacing Screen and Battery
Hi
I had to replace the screen on my 18month old iPhone XS Max after the OE battery swelled and cracked it from the rear. The screen was still functioning (including the digitiser, but the LCD started to bleed.
I replaced it with an OEM screen and the battery with an aftermarket battery. I transferred the serials from the old components to the new ones and the features such as True Tone and 3D Touch appear to work ok, but the battery is showing “Service” but functions as the original did when new.
The issue I am getting is that the digitiser intermittently freezes and I have to lock and unlock the phone. Even this only works 50% of the time and I find that squeezing the screen around the edge (as though trying to re-seal the glue) and then lock/unlock works.
I have tried a third OEM screen and this as the same problem so I am perplexed as to what it the cause of the issue?
When replacing the components (which I have done on about 50 friends and families devices over the years) I always unplug the battery first as I know that there are some sensitive capacitors, etc that can ‘fry’ themselves or adjacent components of not powered down but feel that the issue might be something of this nature that is maybe causing the problem even though I have never experienced an issue of this type every before.
Does anyone have any ideas of the cause of the problem as it’s very annoying and frustrating?
Many thanks in advance for any assistance you can provide
Ash
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Ashley The Reason why that is happening its because one of the components must of been damaged or the replacement OEM Screen and digitizer which you replaced its Faulty and will need to contact the seller and ask you to send you a replacement part.
Thanks John
这个答案有帮助吗?
得分 0
2条评论:
Hi John
Thanks for your reply. Would you have any ideas what sort of component could be damaged as I have already tried a second replacement and the problem persist so thinking it’s a more logic board type of problem but it is a mine field.
Thanks again
Ash
完成的
I would suggest replacing the Logic Board and then take it from there
Thanks John
完成的
添加一条评论
添加你的答案
Ashley Watmough 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 106
