Why is my fan is always running at 7200RPM
My macbook fan is always running at 7000-7200 RPM. From the moment, I press the power button, it starts running very loud, and stays the same. It doesn’t matter what I am doing, it always stays around 7100RPM. I’ve reset de PRAM and the SMC. I’ve installed Fanny and it says:
Fan: #1
Current: 7104 RPM
Min: 1200 RPM
Max: 6500 RPM
Target: 1200 RPM
CPU: 34.75 degrees celcius
GPU: 36.00 degrees celcius
Please help me fix it, the sound of 7200RPM is very loud and annoying.
Update (11/04/2020)
Here is the screenshot.
https://pasteboard.co/JyPPvth.jpg
Please let me know if it doesn't work
Did you try running the onboard diagnostics to see if an error code? Restart the system and press the D key to enter. Tell us what it is.
Reference: Mac startup key combinations
由 Dan 完成的
@danj Thanks for your help. I have already tried that and nothing comes up.
由 Tom 完成的
To be clear you don't get any errors Or it doesn't work?
由 Dan 完成的
Pardon me, I don't get any errors. Sidenote: I've already replaced the thermal paste and cleaned the fans thoroughly.
由 Tom 完成的
OK, lets do this, kill Fanny and install this app TG Pro it will offer a better view of the thermal sensors.
由 Dan 完成的
显示更多的2条评论
