跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Heating up when camera is using in portrait mode.
Hi,
Iphone 8 plus getting hot when camera is using and even more when using in portrait mode. even more heat at and near processor, what is the solution and what will be the issue.
Thank you
Regards
Harsha
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Sharanabasappa,
it looks like your handset is water damaged - heating up when working, that’s damage symptom. You didn't write which camera it was. The camera must be replaced because it affects the operation of the entire system. Eventually it will lead to a short circuit and subsequent damage. If it’s rear cam, just replace it. If front cam, you will lose a TrueTone function.
  • regards,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sharanabasappa G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 97
