跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
371 个问题 查看全部
BSoD (black screen of death) is still there
Alright, my N3DSXL is BSoDing still. I have taken out the battery and the sd card and left it for a while and then tried again but it still BSoD’d. I also took it apart and cleaned all the ribbon cables with 70% Alcohol along with making sure everything was plugged back in. But it still doesnt post. Both displays work because I can go into the update menu and everything works, but it just doesnt boot. It is updated to the newest version also. I am not sure if I will just have to install a new mother board but I just do not understand why it will not boot. It worked on and off throughout the past year and a half, sometimes it would work after a few tries and worked perfectly fine while in use and sometimes could be turned on and off without it not working. But then one day in April after I tried to use it, it would boot to the homescreen and then would freeze before letting me do anything. I tried to start it while plugged in but to no avail. It has not been near magnets, nor any water damage so please, please help. I have stuff on here that I do not want to loose!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I once had this problem, and what fixed it for me was leaving it on, to let the battery slowly die. Once dead recharge it, and it rebooted like normal for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Cox 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 285
