跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
Screwdrivers needed to replace the display and logic-board
Hello,
I would like to ask about the screwdrivers needed to replace the display panel and logic board on the MacBook Pro A1707. I found on the iFixit website that to disassemble the MacBook, i need P5, T5, T3, P2 and TR8. Is the TR8 really necessary when replacing the display and board, or will the classic T8 be enough for me? Where exactly is the TR8 screw used? I found a suitable set of screwdrivers, but it does not contain TR8.
Thank you for answers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The TR bit is the security bit version
It has a pin within the screw preventing a standard T bit to fit. I haven’t needed a TR bit working on the MacBook Pro’s.
Where did you see the need for the TR8 screw being needed?
这个答案有帮助吗?
得分 1
3条评论:
Here at the bottom of the page in the tools category are screwdrivers for A1707 and among them is also TR8. MacBook Pro 15" Touch Bar Late 2016
So will I be able to remove the display and logic board without it?
Thanks
完成的
I figured out the confusion! The display guide calls out a T8 but the tool link is to the TR-8 tool which will work for both! Thats why the lower tools listing calls it out.
To be clear you only need the T8 bit you don'`t need the TR-8 bit.
I'll make a note so it gets corrected.
完成的
Thank you very much! This is exactly what I needed to know :)
完成的
添加一条评论
添加你的答案
Andrej Pracovný účet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 310
