Powers off during boot
Hi,
The laptop powers off during boot. Tried to boot from local drive, USB external, Internet recovery mode. It simply powers off itself when boot progress bar are running. Any ideas?
Thanks!
Have you tried to run an SMC reset? Try that first and then report back! https://support.apple.com/en-us/HT201295
(while powered off, connect to power, then hold left side, shift, control, and option, then press the power button. wait 5 seconds (you might see the mag-safe connector go from green to orange, then green again) then try again)
这个答案有帮助吗?
You could also try holding command and s while attempting to boot and you'll get the single-user-mode console that will show you exactly where it's booting, and maybe you'll see the string that it's failing on to get more insight.
@jabackes Yes, I have tried SMC and PROM reset.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 55
@rouslan - What is the color of the MagSafe LED? Amber or Green or not lit at all!
由 Dan 完成的
@danj The color is green.
由 Rouslan Iskhakov 完成的
OK, that's good!
What do you see if you connect an external monitor to your system or if you aim a flashlight through the lid logo? Do you see a faint image or a clean image on the external.
由 Dan 完成的
@danj I have no external monitor now :-(
@rouslan - Then flash light test
由 Dan 完成的
显示更多的3条评论
