跳转到主内容
加入维修社区 - 创建账户
各种电池的维修指南和文档。
I’m trying to repair a Chargeasap Flash 2.0 battery pack
I’m trying to repair a Chargeasap Flash 2.0 battery pack I received in non working order. The pack says it charges to 100% but won’t turn on and resets to 0%. I have removed labels from top and bottom and removed 6 screws from bottom plastic end but can’t seem to get battery assembly to slide out of metal case. Anybody have an idea how to get battery module out of case?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I finally figured out that the whole module slides out the end with the charge ports. I think there is something wrong with one of the boards. I’m just going to salvage batteries.
这个答案有帮助吗?
得分 0
4条评论:
Hi. Mind tell me how to slide it? Thanks.
完成的
There's a metal plate held in with 6 screws under the bottom sticker (peel carefully) to remove. Then use a hairdryer on the wireless charging cover to soften the adhesive holding the plastic pad to the coil below and push up from the bottom. The wireless cover should pop off and the whole unit should slide easily out the top (USB end). I had to use more force to pop off the wireless charging cover than I was comfortable with, but nothing was destructive.
完成的
Can you share some pictures please :)
完成的
I just got mine open but I don't see a way to add photos
完成的
添加一条评论
添加你的答案
dwarden3 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 724
