跳转到主内容
加入维修社区 - 创建账户
The entry-level version of the Inspiron 15 7000 gaming notebook from June 2017 lacks the higher-end hardware complement of its pricier siblings. The battery life puts many other laptops—gaming or not—to shame.
Touchpad faulty in windows 10
neither the touchpad or mouse buttons work when in windows 10 all the way from the initial set up, the touch pad works in the bios and in a test program however so I’m thinking its a driver issue but I cant find any drivers on Dell’s website which are related to the touchpad.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Have you checked in Windows Start button > Settings > Devices >Touchpad to see if the touchpad has been disabled, you didn't say?
What is the status of the touchpad in Device Manager > Human Interface Devices?
Right click on the Windows Start button and click on the Device Manager link. When in Device Manager scroll down to HID and click on the > symbol to expand the list.
If there is a yellow exclamation mark next to the touchpad entry then there is a driver problem. If you’re connected to the internet, right click on the touchpad entry and select Update driver and follow the prompts.
If there is a red cross then right click on the touchpad entry and select enable and see if it now works OK.
If it all appears to be OK i.e. no crosses or marks then right click on the Touchpad entry and click on Properties > General tab and view what it says in the device status box in the middle. Does it say that “this device is working properly?
Use a USB mouse to navigate through the PC.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ashley Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 15
总计 502
