跳转到主内容
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 个问题 查看全部
Ps4 controller won't turn on or connect unless I reset it
Hello,
My ps4 controller has a problem
I used to connect it to my pc via bluetooth and everything seemed ok until last week
so i connected it to my ps4 and played with it then i put it into rest mode
but the next time i pressed the PS bottun it just kept flashing…it didnt connect automatically, and when the flashing stopped it didnt turn on when i pressed the PS button
so every time i wanna use it i have to reset it or hold the PS button for 10 seconds and then connect it to my ps4 with usb, then it recognized the ps4 and works either wired or wirelessly…
so how can i fix it? im thinking there might be a settings issue
i dont know
thats why im here
sorry about my broken english
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
anyone? i couldnt fix it using the above method
完成的
添加一条评论
1个答案
Hi!
Sounds like it’s searching for your bluetooth device instead the PS4.
Did you removed it from the settings (bluetooth list) at your PC?
This will come in handy, everything about how to do a (hard) reset for the Dualshock 4: https://www.lifewire.com/how-to-reset-ps...
这个答案有帮助吗?
得分 0
3条评论:
thank u for ur answer...yes its no longer connected to my pc...i will try to hard reset it and post a reply on whether it worked
完成的
it didnt help
the problem is still there
完成的
This sounds more likely a software issue instead hardware.
Could you try this?:
https://www.youtube.com/watch?v=1KUUxPO2...
完成的
添加一条评论
添加你的答案
Alireza Gh. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 13
总计 1,635
