跳转到主内容
2015年三月发布的MacBook 11吋使用第五代intel i5/i7处理器,並且拥有比前代稍佳的性能与电池寿命。
Trackpad and Keyboard not Responding. Reference Code: NDR001
Hi everyone,
I’ve recently replaced my display for my MacBook Air. And when I turned it on, the keyboard and trackpad (both built-in) was not responding.
I’ve plugged in a USB mouse and keyboard and it was working fine. Everything else (e.g. the power button, Wi-Fi, bluetooth, webcam, etc) is also working fine.
I also ran a hardware diagnostic test and it gave me reference code NDR001 & NDK001, telling me: There may be an issue with the trackpad.
I’ve also replaced the trackpad cable (pics provided).
I’ve tried replacing the trackpad cable, resetting the PRAM, and SMC. I’m not sure what the issue is.
Thanks everyone
EDIT: Some additional pictures
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
To me it looks like the logic board cable connector is damaged!
Update (10/27/2020)
This is the damaged connector
Compared with this one
这个答案有帮助吗?
得分 1
3条评论:
would this mean that I would need to replace the logic board?
完成的
@m0nsterr - Here's a replacement connector IPD trackpad flex cable connector You do need good soldering skills to do this.
完成的
Thanks! Also, would this be the one on the trackpad or the logic board?
完成的
添加一条评论
添加你的答案
Michelle L 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 17
总计 1,536
