跳转到主内容
除了游戏机本身之外,视频游戏配件可以是任何东西,包括控制器、内存、电源适配器(交流适配器)、音频/视频电缆等。
131 个问题 查看全部
Xbox one Elite 2 controller missing components near right joystick
Hello,
I’ve got a problem with an Xbox Elite 2 Controller. I replaced the right joystick and it works fine except that it does not register a button press of the right joystick.
In the process I may have knocked off two components right next to it:
Any help with identifying the missing components and what to replace them with is much appreciated.
Update:
I really want to know, so I got my hands on another one of these that needs fixing for a good price. This is what the components look like:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
If anyone cares, I managed to fix it. The lower component is a 32 ohm resistor. I just searched old junk PCBs and took one that fits. The upper component is a diode and this one is not critical.
Also there was a broken trace, so I soldered a jumper wire from the button switch to the 32 ohm resistor and everything was working ok then. I skipped replacing the diode because it’s too much trouble in that awkward spot with the broken trace. No clue what the diode is there for.
Desoldering that joystick module was a PITA because the PCB somehow eats up a lot of heat. Much more annoying to work on than the previous controllers! Now all is good :-)
这个答案有帮助吗?
得分 2
添加一条评论
Probably the same as the capacitor next to it. usually when a component forks off in two directions like that the caps are identical.
这个答案有帮助吗?
得分 0
2条评论:
Hi there, thanks! I uploaded another picture with the two components on the board. The component looks different than the cap. Could it be a resistor? The one above it is a small black box, a bit taller than the cap. It's connected by two traces. Could it be a diode maybe?
完成的
i cant really tell what it is in the second photo, to blurry. It kinda looks like a switch,
完成的
添加一条评论
Hey Chris,
Thank you for posting this! Because of you I was able to fix a elite 2 controller I bought for a good price to fix. I had given up because there were some components missing but because you found out it wasn't a necessary component I just put in New sticks and tried it and voila it works again. Now I need a new battery because the one that is in there is swollen. Anyways thanks for all your hard work it has really helped me with my controller :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 316
