跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
MacBook SERVICE BATTERY status and where is it stored?
I know for a fact that Service Battery status is stored in OSX files somewhere but not sure where??
  • Reinstalling Macbook removes this status.
  • Running Macbook from external OSX removes this status.
  • Reinstalling OSX and migrating original OSX removes the status.
Id like to know where is this status hidden in OSX files to remove it without reinstalling??
Anyone has any idea where to look for it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The OS does not hold the setting! What you encountered is when the OS install process ran it cleared the setting held in the SMC EEROM area after SMC has read off the battery cycle count and/or when the voltage sensor drops below a set threshold.
You can see the see your batteries status using CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
It does sound like you need to replace your battery MacBook Pro(13 英寸,配备 Retina 显示屏2015 年初期)电池更换
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
MacBook Pro 13" Retina Display Early 2015 电池图片
指南
难度:
困难
45 minutes - 2 hours
这个答案有帮助吗?
得分 0
4条评论:
Not sure if you are correct. I can start this Macbook using other USB boot drive with different OSX and status is gone. No installation there and NO SMC reset done.
It feels to me like the setting is stored in OSX somewhere and not in SMC or battery.
Also 3 days ago I reinstalled customers Macbook with Service Battery status. Status was gone on clean osx and after migrating the data. I am doing full battery cycles for 3 days and status is not comming back.
完成的
@windcatcher - How to reset SMC How to reset the SMC of your Mac Note "the can resolve certain issues related to power, battery, fans, and other features." Does that help you explain why this is not software but a hardware level issue.
How about running CoconutBattery and posting a snapshot to prove me wrong ;-}
完成的
@danj
Ressetting SMC, resseting PRAM or unplugging battery never fix this status nowadays.
Starting with different USB boot drive or fresh install always fix this status and that is why I suspect some flag in OSX files and not only SMC EEROM.
I repair Macs and have many of them every day.
Some of it are used on a charger all the time and get service battery status. In most cases battery is still fine ...
What I need is fast way of removing this status and then instructing the user to properly charge &discharge it every few days.
完成的
@windcatcher - Without seeing CoconutBattery screenshot you are not telling me anything useful to figure out what's wrong. Just because your symptoms go away magically is useless info.
Using sound engineering processes and diagnostics is the only way we can move forward here.
完成的
添加一条评论
添加你的答案
Windcatcher 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 87
