跳转到主内容
The OnePlus 6T is an Android smartphone made by OnePlus. It was announced on October 29, 2018 and released on November 6, 2018.
26 个问题 查看全部
The guides are missing the part where you put back the back cover
  • Do you have to buy an adhesive?
  • Do you have to apply fresh silicon ?
  • Do the new back covers come with pre-applied adhesive or silicon ?
  • Does the existing material of the old back cover glue back if heated ?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Typically you peel off the old adhesive and replace it with new stuff. Don’t use silicone, use something like Tesa black tape. Some parts suppliers will sell precut adhesive for most devices. Some suppliers will also sell back covers with new adhesive either already attached or you need to apply it. In some cases, if you cut through the adhesive clean enough you can reuse it. Just put the back cover back on, use some heat from a heat gun or hair dryer, and then either clamp it down for about 20 minutes or put some heavy books on it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kriegalex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 178
