跳转到主内容
Device repair information for the first generation of V-Moda Crossfade Wireless headphones.
short circuit from water damage; does not charge
Got caught in heavy rain with my headphones on and didn’t think much of it bc i’m an idiot. They continued to function without issue for a few days (no problems with playback or bluetooth pairing they honestly seemed fine, they also still work when using the cable for a wired connection) but once the battery started to get low i discovered that they would not charge at all. additionally the wires connecting the earcups to the headband quickly became very hot whenever i attempted to charge the battery, still without success. regular phone repair stores have refused to touch them and i really don’t wanna buy new ones, all advice is appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @beetlebert
The water causes corrosion and provides circuit paths for the electricity which were not in the earphone’s operating design and could damage the components. The corrosion starts immediately and doesn’t stop until it has been properly cleaned away.
Do not try to charge or to turn on the earphones and remove the battery as soon as possible so as to minimize any further problems.
Then you need to disassemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the concentration (%) of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb, be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
The battery may have to be replaced. Check the type number and search online using the number.
Hopefully after you have done all this, they might possibly work correctly again.
Here is a link to the ifixit V-Moda Crossfade Wireless Headphones Battery Replacement guide that may help.
You can only try and see if this resolves the problem.
Good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
max 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 25
总计 1,459
