跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
iPhone XS laging and restarting after 3mn
Hello,
I did a back glass replacement and after reassembling the phone. It is laging. I tried to do some troubleshooting
1- when i disconnect the back and front camera the phone works well with no lag
2- when i connect only the back camera the phone lags ( the camera is work but not a the first attempt )
3- when i connect only the front camera the phone lags ( and face id says “face not visible” )
4- when i connected both cameras, phone lags ( both cameras are working, but the flash doesnt )
5- For the restarting issue i think i damaged the charging port while removing the back glass. I read that in another forum
Please help. I dont know what else to do
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Back Glass or Whole Housing replacements can suffer from the same issues, mainly damaged flexes or connectors. If the phone works fine without the cameras, then closely examine the camera flexes and connectors (and the equivalent connectors on the logic board.
Look for tears in the flexes, even the tiniest ones. Sometimes the connector pins get damaged or some surrounding components can be fully or partially dislodged. All of this inspection may require some magnification.
EDIT 2020-10-26
Take a closer at this flex, based on your picture below (https://ibb.co/g9qRMTj).
这个答案有帮助吗?
得分 2
2条评论:
I doublechecked the connectors and the flexs but i haven´t seen any damages. These are some macroshoots i took, maybe there can be helpful.
What about the restart after 3minutes ? Is It the Charging port which needs to be replaced ?
https://ibb.co/G2yvSwF
https://ibb.co/7kYG0Q4
https://ibb.co/D8gF0FP
https://ibb.co/F3nXKRQ
https://ibb.co/QJcmmXK
https://ibb.co/VWcXHDD
https://ibb.co/pR8S4CS
https://ibb.co/cCbscS9
https://ibb.co/GPqB8m9
https://ibb.co/wzyrhQ7
https://ibb.co/Kh1Bntb
https://ibb.co/H4vmPSY
https://ibb.co/9HXD2gs
完成的
I double checked the flex but it is not damaged. i took a better picture
https://ibb.co/N1WHX5W
完成的
添加一条评论
Hello Michel,
While the phone is on connect it to your pc run CoconutBattery app: https://www.coconut-flavour.com/coconutb...
If the design capacity shows value around 100mAh (normal value would be the thousands range ~2000-2658mAh)it would suggest you damaged either the battery connector or a tiny component around the connector. If that’s the case you would need a professional to fix it. It would help if you cold post pictures of the battery connector in question.
这个答案有帮助吗?
得分 0
1条评论:
Heloo Roman,
thank for your response. I don´t have a Mac but a Windows PC. I used 3UTools to check the Ah. It shows 2642mAh as designed capacity.
These are some pictures.
https://ibb.co/yVmM1Nf
https://ibb.co/m0x4VDt
https://ibb.co/TYgWYBq
https://ibb.co/yYcyFq2
完成的
添加一条评论
Did you figured the issue? Because I have the exact same issue.
I replaced the charging flex cable with new OEM and still the issue is there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michel Ngne 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 262
