跳转到主内容
加入维修社区 - 创建账户
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Diagnosis code PPF003 question
My fans is running constantly. The diagnostic code is PPF003. Apple advise that it is a fan issue and that it should be taken to a service center. But surely it’s the thing that switches the fan on and off that’s the issue. I have reset the SMC. I don’t want to replace the fan only to find that the new fan runs constantly. Any suggestions/comments?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Within the fan is a tachometer to monitor the fan’s RPM (feedback) that way the SMC logic can make sure to set the fan as the correct cooling level needed.
The error PPF003 really doesn’t tell us if the fan its self or the controlling logic is the problem. The easiest way is just replace the fan to see if that solves the problem or not. MacBook Air 13" (Late 2010-2017) Fan and here’s there guide to put it in MacBook Air 13" Mid 2013 Fan Replacement.
I would first get a soft paint brush and a can of can’ed air to clean the dust and debris thats collected inside out. Your fan may every come back to life! You may want to use a better way to monitor your systems thermals, I like this tool TG Pro
Replace a fan compatible with Late 2010 to 2017 MacBook Air 13" A1369 or A1466 model laptops. Part #923-0442, 923-00507.图片
产品
$29.99
这个答案有帮助吗?
得分 0
1条评论:
I cleaned the fan. I replaced the fan with a new one. Still the fan runs at full speed. I installed TPPro - no temperature issues. I ran ASD EFI software. “sensor - voltage (VPOR) — PBus reading below limit” No other sensor issues. Where is this sensor - anyone know?
完成的
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 636
