跳转到主内容
The iO, released in 2020 is an electric toothbrush by Oral-B. It is able to connect to your smartphone via Bluetooth and gives you realtime 3D teeth tracking. Model: Oral-B iO 9
16 个问题 查看全部
Are the Series 7 and Series 8 as easy to disassemble as the series 9?
I like that the battery is replaceable in the Series 9 without having to desolder anything. Can the Series 7 and Series 8 similarly disassembled without the use of a soldering iron?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Battery is slip in for the Oral B iO 8.Use the bottom of the charging stand to unscrew bottom brush cover and push out insides.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gilmanwong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 994
