跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
125 个问题 查看全部
Apple Watch freezing every time
My Apple Watch series 4 freezing every time , sometimes works perfectly for couple of hours
I’m unpairing repairing every time
hard reset can’t resolve this issue
I tried with several iPhones & updated Watch os
still same sometimes Digital Crown stopped working
screen is always freezing how can I fix this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
That sounds like a logic board issue, your best bet may be to try swapping in some parts but if that doesn’t work you might have to buy a new watch.
这个答案有帮助吗?
得分 0
4条评论:
Which parts needs to be swap
完成的
everything except the logic board
完成的
I replaced the screen & new battery still problems persisting
完成的
said everything, not just screen and batt
完成的
添加一条评论
If you are still having issues, try this.
  1. Force restart the device (hold the crown and power button)
  2. Once the device turns off, let go of both buttons. When the apple logo appears, hold the power button (lower right one) until the erase all content option appears
  3. Follow the prompts and allow the device to reset.
  4. Pair the device again
Hope this helps!!
这个答案有帮助吗?
得分 0
1条评论:
I tried several times
It was working for week then goes to freezing again
完成的
添加一条评论
添加你的答案
Shaheen Sultana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 176
