跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 7 and iPhone 8 rear cameras are the same?
Hi Guys just a quickie, have scraped the internet for this answer but have found nothing concrete.
I have read that both cameras are built exactly the same, have same specs, but obviously the 8 has better software to implement a better picture. However physically and build wise it appears identical. I have one to sell on ebay (Iphone 7) but if I advertise it as an Iphone 8 rear camera I can ask for twice as much. Will I get away with it or is there a slight inherent difference between the two ?
Sean.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sorry you can’t the iPhone 7 rear camera flex cable has 22 pins while the iPhone 8 rear camera flex cable has 24 pins.
这个答案有帮助吗?
得分 0
4条评论:
Dam it lol, I knew there must have been a reason apart from the camera housing being a light gold colour, thanks so much for your quick reply. I have started up fixing phones and laptops just to get me through this pandemic so I will return lol.
Sean.
完成的
Excuse me, do you mean that the iPhone 7 and 8 rear cameras are the same?
完成的
@kmekmiv5keesph8 I'm not sure what you're reading here, but Roman's information is specifically saying that the cameras are NOT the same; the connectors have a different number of pins and therefore are not interchangeable. The camera hardware itself may or may not be the same, but there's a reason that there's a different number of pins so there's definitely an electrical difference between them.
完成的
I finally understand. Thank you very much.
完成的
添加一条评论
添加你的答案
Sean Murray 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 10
过去 30 天: 67
总计 2,186
