跳转到主内容
D-Ram Light on mother board when I turn it on.
D-Ram Light on mother board when i turn it on.
theirs nothing showing on monitors.
motherboard; asus tuf z390 gaming pro
gpu; amd radeon rx 580
ram; ADATA DDR4 32gb( 2 sticks)
power supply; Seasonic cor gm-650, 650 w
what iv tried;
iv re-seated the ram like 5 to 6 times., iv tried 1 stick , iv tried re-seatin the gpu and cpu aswel.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @planetpatrick
is it a new system? or it happened recently?
possible to get another brand / manufacturer RAM to test out?
https://www.asus.com/support/FAQ/1042678....
完成的
@salmonjapan motherboard and psu is new. i ordered new ram. so hopefully thats the issue. i mean , with no ram in, the dram light still comes on
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @planetpatrick ,
If it is a new build just verifying that the ram modules are installed in the DIMM A2 and DIMM B2 slots?
If one ram module only, it should be inserted into the DIMM A2 slot
This is from the user manual
(click on image to enlarge for better viewing)
Also what CPU is installed?
Here’s the Asus supported CPU list for the motheboard.
这个答案有帮助吗?
得分 3
1条评论:
Hi @planetpatrick ,
With no ram module inserted it is normal that the DRAM light is on as it indicates that the ram is not properly installed i.e. it cannot be detected or accessed as it is not there as far as the BIOS is concerned.
完成的
添加一条评论
添加你的答案
Patrick Driscoll 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 66
