跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
SSD is not recognised any more
I’ve updated my iMacs HDD to a Samsung 860EVO 2TB. Everything was fine until i opened the imac to align the Thunderbolt ports to the chassis (check my other issue Thunderbolt ports (USB-C) no longer working).
After i aligned the logic board to the chassis i turned on the computer and saw the prohibitory symbol (do not enter).
Tried to enter with the alt key, i see Macintosh HD as a drive but it wont boot, once i select it i see the prohibitory symbol.
Tried to enter in recovery mode but disck utility doesn’t see the SSD.
Tried to enter single user mode but i get the message: Error loading kernel cache 0x7
The imac came with a fusion drive. The old boot system is still installed from what i understand.
I tried to power cycle the SSD - boot with alt key, wait in the menu for 30 mins, then turn off for 30 secs and repeat. Nothing worked. I read that this method can revive an SSD if its “broken”.
I then took out the SSD and put it in an external 2,5 enclosure and connected it on my MacBookPro but it won’t show up as well.
Is the SSD dead?
Update (10/20/2020)
So, a big update!
As a last resort , and i dont know why, i dismantled the imac and put it back together with the old (dead) SSD
I booted the computer and after 20 secs of the STOP symbol the iMac booted and everything is fine...
I backed up everything that is important
I tried deleting some files and i was getting an error, i did a first aid through disk utility and everything is back to normal, its just that everytime i start the iMac i get the STOP symbol for a couple of secs
Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
15条评论
Did you format the SSD to APFS? APFS (Apple File System) is Apple's "special" format for their HDDs and SSDs.
完成的
That was maybe a year ago but yes as far as i remember
完成的
@jflys5000 & @George Anagnostopoulos - To clarify: macOS High Sierra and newer requires APFS and the installer will convert the older HFS+ file system to APFS if it is found.
Unless you are still running the original OS the system came with macOS Sierra (10.12.x) which is the last macOS with the HFS+ file system, the system will be APFS.
完成的
So to clarify things, you just loosened the screws holding the logic board - Correct?
The only thing I can think of is you caught the HD SATA cable crushing it. I don't think the SSD is damaged.
完成的
the cable is fine physically. If the SSD is ok, why wouldnt it show up on my laptop connected to an external enclosure?
完成的
显示更多的10条评论
添加一条评论
1个答案
最有帮助的答案
You still have an issue as the blade SSD on the back side of the logic board misses its mate! You should pull it so it doesn’t get you into trouble.
You’ll likely need to pull the logic board to see what you did with the HD SATA cable at this point any ways.
Update (11/04/2020)
OK this is starting to look like the Startup Disk setting is messed up. Restart your system and press the Option (⌥) key to gain access to the Startup Manager, select your boot drive, your system should start right up, did it?
If it did then go inter your Preferences, open Startup Disk and reset your boot drive. Restart your system it should now properly start up.
Reference: Mac startup key combinations
这个答案有帮助吗?
得分 1
1条评论:
Thanks Dan will check but i also might give it to a repair centre for diagnosis, i think that the Samsung SSD died...
完成的
添加一条评论
添加你的答案
George Anagnostopoulos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 266
