跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
No backlight NO Image problem
Hello Guys! This is an advanced question.
iPhone SE NO backlight and NO image. I have already replaced every components on the backlight line (filters, diods, IC)
The Original screen is working for SURE (tested it)
Mainboard connectors are all tested good.
Phone works, and boots I know because when I plug in the charger cable the charging sound comes in.
What is the next step to do to further investigate?
Blow photos are taken right after I opened up the phone:
Update (11/24/2020)
Thank you for taking the time for answering. Unfortunately I have decided to stop investing time for now. I have other stuff to do so I’ll put it for side now. :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
How is the display driver?
完成的
@mrgeek Display driver has been changed to a new one.
完成的
添加一条评论
1个答案
已选择的解决方案
Forget about the backlight until you have image. You said mainboard connectors all tested well. So you are getting
·         1V8 on pin 5?
·         5V7 on pin 1 and 3?
What are diode readings of pin 7 and 9?
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Peter Hupuczi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 564
