跳转到主内容
加入维修社区 - 创建账户
三星 F90 500 万像素黑色摄像机,配备 2.7 英寸 LCD 屏幕,旨在用于通用高清视频录制。该设备目前已停产,型号为 HMX-F90。
How can I replace the INTERNAL battery on Samsung HMX-F90?
The internal battery on my Samsung HMX-F90 needs to be replaced because each time I pull the regular battery the Date/Time needs to be reset. Anyone have any experience with this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
try contacting Samsung, I can't even find replacements.
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Hi @junkernaut ,
Here’s the service manual for the camera. Be patient as it takes a little while to go from processing to download after you have passed the security check and clicked on Go to Download, below the document preview box.
Sect 3. of the manual show the disassembly procedure
Here’s a composite of two images from the manual showing the battery location on the mainboard pcb diagram on the right and the wiring diagram on the left.
(click on image to enlarge for better viewing)
The image on the right shows that the part number is 2409-001166.
Also it appears to be a capacitor and not a battery per se, the value being 70000uF (0.07F)
Search online using the part number only to find suppliers. A lot that I checked say that it is available as a special order, but you may find a supplier that has one in stock.
这个答案有帮助吗?
得分 2
1条评论:
@jayeff Thanks so much for this info!! Just what I was looking for!
由完成的 分享
添加一条评论
添加你的答案
justin roth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 30
总计 874
