跳转到主内容
加入维修社区 - 创建账户
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
NFC and Bluetooth problems
Where is this located? Dropped the phone on the top in an otter box but now the NFC doesn’t work and Bluetooth audio streaming keeps dropping and reconnecting. Bluetooth phone calls are fine. Flashlight is also spotty works and doesn’t sometimes. Is this a connector or a brass pin connector or a bad chip? Already had this issue and phone was replaced under limited warranty. It’s happening again after a drop. I work in the field. Update: it drops connection when the top of the phone is sandwiched lightly Around the area of the mute switch. If I squeeze it, it drops and comes back after a few seconds. It’s a full drop connection
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You should check the flex connectors are all seated properly. It does sound like a connection problem and the 11 Max is a layered board. The solder they use to connect the two layers in my standards is poor quality and the phone only needs a slight drop for the solder balls to crack and become oxidised.
I think you will have to have it looked at by a reputable repairer who would separate the board, check the pads than re-ball it with some quality solder.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matt Bray 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 43
总计 1,067
