跳转到主内容
加入维修社区 - 创建账户
Repair information for Whirlpool dishwashers.
it doesn't get anything clean and won't dry
The truth is Whirlpool is a piece of $@$*! I purchased a house from Del Webb in Richmond TX. The Dishwasher handle came off after 1 month normal use. Called Whirlpool service, service man came and said its cosmetic.. Not covered.
We open with a screwdriver. Now it doesn't get anything clean and won't dry.
Was advised by whirlpool to increase water temp on water heater. Now at 120 F still doesn't work. Don't buy Whirlpool, JUNK
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Harry Vogelfang - The dishwasher has a 1 year manufacturers warranty from the date you closed on the house, if it was a new house and new dishwasher. The door latch is a mechanical part and is not cosmetic. The tech should have given you a price for the part. He could have even had it shipped to your home n you could have put it on. The not cleaning issue. Again, I’m assuming this is a new dishwasher still covered by the 1st year warranty. The unit drains into the disposal. You’ll see the drain hose connection in the middle of disposal. Looking under the sink at the drain hose, does the hose loop up then down and into disposal? If not, all the stuff that you put in disposal and mixed with the water with tend to run down the drain hose into dishwasher. Re arrange the hose so it goes up then down into to disposal. Look at spayarms in d/w for food hanging out holes on sprayarms. That’s a sign drain isn’t looped. I see that a lot in new home and it’s not covered under warranty cuz it’s not the d/w.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Harry Vogelfang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 106
