跳转到主内容
加入维修社区 - 创建账户
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
When I do my lockscreen, it says try again in 30 seconds what do I do
Hello. I have a samsung tablet that does not work right now. I draw my pattern on my lockscreen and it says "try again in 30 seconds" and I'm not sure what to do i'm typing the right password and I'm currently typing this from a computer. Is there any way you could help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
Do u solution already
I this problem today
完成的
Power off then power on
完成的
添加一条评论
2个答案
最有帮助的答案
You could try restarting the tablet or performing a factory reset. If you can’t get in the tablet the procedure to factory reset is as follows:
https://www.verizon.com/support/knowledg...
这个答案有帮助吗?
得分 4
2条评论:
I hv done it nothing hppen
Volume up + power
My screen on sleep
完成的
@ujaejang Power off your tablet first, then do volume up+ power.
完成的
添加一条评论
I just simply restarted it, and everything went back to normal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Atenea Estulin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 7,318
