跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for electronic keyboards.
Concertmate 680 won't turn on while powered.
I have found an old concertmate 680 from a few years back. It was stored in near proper conditions as far as I can tell. I’ve tried to power it on using both the DC adapter and using batteries, but it won’t turn on. Does anybody have a potential solution I can use?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
There is not much information out there about your model keyboard but I managed to find the service manual online, (if you wish to purchase it), which should be of some help as usually most service manuals have dis-assembly instructions and schematic diagrams
If there is no indication of power when the power is switched to On then you will have to open the keyboard and check the circuit from the power supply inputs, both battery and adapter (although they should common up somewhere near the power switch) to the power switch and then through the switch and further into the circuit.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lowertrack 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 539
