跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
165 个问题 查看全部
iPhone freezing after screen replacement
I replaced the Digitizer on an iPhone 11 Pro Max and it seemed to work fine during testing. The customer called a couple hours later saying the phone is freezing. It works fine after a hard reset but only for about an hour then freezes up again. Any suggestions? Could it be the aftermarket LCD I installed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It could be a bad screen or perhaps something went wrong during the repair. Obviously, you should take a closer look to see if any of the flexes are damaged or if any components were damaged or dislodged near the relevant connectors.
As a repair shop, you probably have other screens so I would try one of those first. If you still have the customers original screen and it is functional, try that one too.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kenny G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 38
总计 1,429
