跳转到主内容
加入维修社区 - 创建账户
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
iPhone stuck in boot loop?
Okay so this morning my phone was working properly, I woke up, set another alarm, then went back to bed. When I woke up (late bc my alarm never went off) my phone was stuck on the spinning circle that appears when your phone dies. I figured it was dead and plugged it in. After a while it didn’t go away, so I force restarted it. This got rid of the circle, but now my phones stuck in a boot loop. I tried to force restart it multiple times, and it just goes back into the boot loop. I put it in recovery mode and connected it to my laptop but it just went back in the loop. It never came into contact with water or got damaged in any was as I was literally asleep. What do I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Was the phone connected to a charger when this happened? And if so, was it an original charger and Lightning cable? Low quality chargers are known to cause issues with the charge circuit in the phone.
If that isn’t the case, while it could be a spontaneous failure, the problem may also be caused by a (or multiple) previous events, such as drops, poor quality car chargers and even some minor water ingress that goes unnoticed.
If you want to continue with a DIY approach, I would open it up and take a quick look to see if there are any signs of water. You could also try a new battery but this kind of failure points more towards a logic board issue.
Let us know what you find and we can help you with more detailed answers.
这个答案有帮助吗?
得分 2
1条评论:
It wasn't plugged in, idk if there was water damage but i could check. I'm gonna try connecting it to itunes soon as its currently in recovery mode, i'll see if resetting it through that helps first. Thanks!!
完成的
添加一条评论
添加你的答案
Isabella 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 570
