跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
125 个问题 查看全部
Possible to re-assemble with damaged force touch?
No surprise, I’ve damaged my force touch gasket while replacing the battery on my 44MM series 4 watch. The watch has been dead since before WatchOS 7 so is still on the last major release. Any thoughts on whether the device could be re-assembled with a damaged Force Touch gasket and will operate enough to install a new OS since the feature is disabled?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The easiest way to test this is to put the screen back on. Leave it lose and don't glue it down. Turning the watch back on without the screen being glued down won't damage the watch. Force touch gasket costs about 2 quid and as far as I know the watch won't properly function without it
这个答案有帮助吗?
得分 1
1条评论:
Here's the needed part: [[ 无效部分链接 ]]
完成的
添加一条评论
The device can be assembled without the force touch gasket, however you will lose the force touch functionality
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
rmlotz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 137
