跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Possible IC chip damage?
Some days ago I put my iPhone SE to charge overnight with a MFi certified cable and a random usb wall plug, as I didn’t have the original charger around that day, but I thought having a genuine cable was enough to prevent possible damage to the device.
The iPhone had still a good percentage of battery left when I put it to charge at night, but the next morning it was completely dead, while still connected to the charger. No power up, no low battery indicator, doesn’t get recognized by iTunes.
The cable and usb charger aren’t damaged and still work with another device. I’ve opened the SE and did some tests with a multimeter, and here’s what I got so far:
  • No obvious signs of damage inside the case, neither inside the lightning port
  • The battery voltage is 3.4V; I replaced it two months ago with an iFixit battery so it’s highly unlikely that could be the problem. Anyways I disconnected it and connected the old original battery (which probably no charge, but had a voltage of 3V) but no signs of improvement
  • With the phone connected under charge, the multimeter reads 0V from the pins inside the battery connector socket
All this makes me think the Tristarchip is damaged and so there’s nothing worth doing to the phone, as sending it to repair this kind of problem would probably cost more than another used iPhone SE now. However I still want to exclude any other possible culprit; for example could the cause be the lightning dock instead?
I’d like to know if in your opinion is the port or anything else worth checking or replacing, before spending 30$ for a new port that might be better invested in buying a new phone; or if these symptoms indicate almost certain chip failure.
To clarify, I’m no expert in iPhone internal electronics besides having done some basic replacements, and know about the tristar stuff from reading about it in the past days.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Based on your description, it certainly appears to be a charge circuit issue.
A Tristar repair wouldn’t be that expensive, probably less than the value of a replacement phone; look and call around in your area to be certain. Besides, if you’re going to spend $30 for a replacement charge port, better off to invest that in a micro-soldering repair and have a functional phone. The micro-solderer will try a charge port anyway before doing any board work (at least, they should).
这个答案有帮助吗?
得分 2
1条评论:
Thank you for the advice
完成的
添加一条评论
添加你的答案
Raziocinjo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 1,356
