跳转到主内容
This full-featured mainstream Laptop enhances the previous generation Dell models with the chipsets and new levels of customization for the best experience on your Dell Inspiron 1300 Laptop with improved performance, make it easy to create a home network and share all of your favorite items.
2 个问题 查看全部
Can I replace Dell laptop cooling fan with any other fan?
Im trying to get this Dell Inspiron 1300 working again. The fan is dead and getting a new or used seem hard. So I end up with an idea to take another fan from Lenovo. Cut the edges with a saw and fitted it. They both three cables fans. Just colours differ.
After assembling it back I can’t get this fan to work. It spins for a two seconds and stops. Any ideas that might help? Or maybe i’ve just damaged this fan with a saw.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @lost_in_spice ,
Are the specifications on the replacement fan the same as for the original? According to this link it is a 5V 1.8W fan. The specifications should be marked on the centre of the fan
If the specifications are the same then perhaps the sensor in the fan (not sure if it is a rpm sensor or temp sensor) or sensor lead (yellow wire) is faulty
There are some fans online. Just search for Dell Inspiron 1300 fan or MD538. Here’s just one
这个答案有帮助吗?
得分 1
1条评论:
Well. Didn't think about that. Fan I took out from Dell didn't had a sticker.
So I'm assuming I need a fan with 0.36A. the one I've installed is 0.5A so that's why it's not working. I've noticed there are some fans for dell. But either in US or China and I don't want to pay 30 quids or wait two months. Upcycling to its best. Thanks for help!
完成的
添加一条评论
添加你的答案
D. K. Labudek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 129
