跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
Does the stand from 24" Cinema Display fit on 27" model?
Will buy a 27” Cinema Display, but it has the VESA mount (doesn’t have stand), but I do have a stand from the 24” model, so, can anyone advise if I can install it on the 27” version?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It will look quite odd! The stand will have the display at a lower point, likely scraping the bottom edge!
You really want to get either a VESA mount stand or replace the stand with the correct one.
There are some nice VESA mount stands that don’t need to be mounted to a desk if that was your concern.
这个答案有帮助吗?
得分 1
6条评论:
OK, thanks for your comment.
完成的
@lovecd - I did find the Apple P/N for the correct part 27" LED Cinema Display Leg/Stand, Apple P/N 922-9345
完成的
looks like it is hardly find that part available now.
完成的
@lovecd - True! Parts are getting hard for this older display. I would stick with the VESA mount stand Workstream by Monoprice - Easy Height-Adjustable Free Standing Single Monitor Desk Mount for Monitors Up To 27"
完成的
Yeah, I think I will go that route, thanks Dan!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 218
