跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
iPhone 6s plus backlight half display
So i have 6s plus and i change broken display and battery,al always i disconecr battery first and then all other and first connect new display then battery all works great but i got darker left side on screen why? I try few times reconnect connectors and clean with alcohol but no luck…on orginal display was right site now i change display and now is the left site haha why? Pls help se image
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
This is a backlight problem on the logic board. The 6s plus has two backlight driver IC’s One of them has failed causing the problem you are having.
You will need to replace the faulty IC by a reputable repairer.
这个答案有帮助吗?
得分 4
5条评论:
As for the backlight issue switching sides, different screen makers/refurbishers may apply different backlights which may have the connections reversed.
完成的
@refectio I didn’t think of that Minho. So this could be another faulty component on the backlight circuit. Like filter of diode? You learn something every day.
完成的
Thanks,but what now? Is diode?filter? Do i need to change this or what? I will go today to test one display to my local shop and will give and update if its the screen or like you say myb filter or diode...
And where are those located on motherboard? Thanks
完成的
I was in my local shop and they try screen on his screen is also on left site black,on my screen is also left site and on my ORGINAL screen is right site...how?why? What now?
完成的
One of the two backlight circuits, as Chris has already mentioned, is damaged. That's why the screen is dark on one side but not the other. It could be a diode, filter or IC (or all of them, each case is different). This is a very common issue on the 6S series and is usually caused by connecting a screen while the battery is still connected to the logic board. This can only be repaired via microsoldering and is not a DIY repair.
As for the darkness occurring on different sides, this is strictly related to the screen and is not something of concern. A replacement screen is a multi-layer sandwich, one of the layers being the actual backlight. Different backlight manufacturers use different configurations, for example the left side being controlled by driver 1 or driver 2. It makes no difference when both backlight drivers are working properly.
完成的
添加一条评论
If it happened with two displays then most likely it’s a board issue. But I’m confused as to why it switched sides…
这个答案有帮助吗?
得分 1
2条评论:
Yes i am also confused,on orginal was right sad darker but now when i change it it is left side but as you cen see is not the hole left side
完成的
What can be? Diode? Backlight filter? Or what?
完成的
添加一条评论
The backlight is working so I don’t think it is a board issue, because all of the LEDs in the matrix would be off if that were the case. Are you able to test your new display assembly on a different iPhone 6S?
这个答案有帮助吗?
得分 0
3条评论:
Tommorow i will go to check it,but orginal display also was the same problem but on the right side...
完成的
The touch working,camera and everything...
完成的
The digitizer and front-facing camera flex are two separate components, so it makes sense that they may still function fine.
完成的
添加一条评论
添加你的答案
Mateus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 948
