跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone - calls don't work, text and data OK. Specific to sim and phone
Hi, I'm having a real head-scratcher after trying every troubleshooting option under the sun..
Basically, I've ported my number from another phone provider. I received their sim card and it doesn't make or receive calls (data and text are OK), and the reception is quite sketchy.
But here's the weird part: when I test the new sim in another phone - the sim can make calls fine, so the sim works. Then, when I try another sim in my phone, that sim can make calls. So the phone works OK...
For whatever reason, this specific phone providers sim in this specific phone can't make calls, and has trouble finding reception.
I've called apple, the phone hardware got a green light after a diagnostic. I've reset network settings, reset the entire phone, I've bought a brand new replacement sim, the phone isn't locked - all leaves me with the same issue.
I'm wondering whether something when wrong in the porting process, or something on my phone isn't written correctly as it relates to this specific provider. My provider is looking into it now
Appreciate any help as I'm all out of normal troubleshooting options.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
This could be either due to carrier or the phone, or both.
Likely scenario 1:
  • Carrier do not support VoLTE, or the service is not enabled on the number/device, therefore CSFB is needed.
  • The carrier’s 3G service is deployed on a band or technology that the phone does not support, or it technically supports, but broken.
Likely scenario 2:
  • Bad carrier provision, which resulted in non-standard signaling behavior that happens to be not supported by this device, or its specific baseband software version.
Since no specific carrier or device model is mentioned, no cross-testing of various carriers and devices has been performed, we can only guess now.
这个答案有帮助吗?
得分 2
1条评论:
Hi Tom, thanks very much for this feedback. I should have been specific with the devices and carriers so apologies for that.
My phone = iPhone 7
My SIM/carrier = Belong (Telstra) in Australia
Test phone = iPhone 6, iPhone XS (both successful in making calls with Belong SIM)
Test SIM = Telstra, Optus (both successful in making calls with my iPhone 7)
完成的
添加一条评论
The other tester phone that you’re using, is that an iPhone 7 as well? I know reception can vary from not only between different carriers, but also different devices. And usually iPhones are pretty good when they change from one carrier to another compared to android because they sell the same variant for just about every carrier vs android which will have a few different variants per model for each carrier.
这个答案有帮助吗?
得分 0
添加一条评论
What is the model of the phone? it should say on the back. Apple has a service free to iphone 7s that have the no service issue. For instance, I have an a1660, which is affected by the defect. They will repair it for free if it meets the criteria
https://support.apple.com/iphone-7-no-se...
这个答案有帮助吗?
得分 0
2条评论:
Thanks Dylan, good option. I had a look and my phone isn't on that model list unfortunately.
完成的
@nobuo aww. Thats too bad. Hope you find a solution.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 92
