跳转到主内容
Problems with screen after long time not using
Had it lying around for about 1~2 years. After charging up and open back the screen turns into some water-ish damage almost entire screen while the edges still looked normal.
Is the screen panel damaged? Or is it some steam trapped between screen panel and glass panel?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You'll need to plug in an external monitor to be sure you don't have anything deeper.
If you are able to get it going enough I would also check your battery as it likely needs replacing, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
最有帮助的答案
I have seen this before; unfortunately, your LCD has suffered permanent damage. I can’t give you an exact reason why this happens, as there are many, but in most cases, this can be attributed to either too much heat or pressure on the display. If this machine was sitting somewhere that gets a lot of sunlight, or stacked beneath other items for a prolonged period of time, this problem will develop.
You will need to replace the LCD or the entire display assembly (whatever you’re more comfortable doing).
Sorry for the bad news.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lee Han Chang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 131
