跳转到主内容
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Why can't my PS3 enter standby mode?
When I power on my PS3 40GB (CECHJ04), it seemingly acts fine, but there is no signal getting to the TV. I’ve tried changing TVs, HDMI cables, component, nothing. Tried to reset the output settings by holding power until the second beep, cleaning the inside, all for naught.
After trying to get it back running for a few days, I also noticed that there’s no red light whatsoever. It just doesn’t glow red (or yellow) and it can’t enter standby. Atleast I am assuming so, as I can’t see anything changing on my TV. Also, it doesn’t turn off by itself, even after hours on end. The fan is just spinning quietly, the LED is solid green and the disc drive functions properly.
So, should I even bother buying a new HDD, applying new thermal paste or changing the motherboards battery? I don’t wan’t to use it myself, just want to fix it because I like to repair “retro“ consoles.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
that’s a power state feature, the internal power supply or main board may have debris shorting or limiting it’s use.
这个答案有帮助吗?
得分 1
1条评论:
Thank you.
Removing the debris might be enough then. Are there more potential causes for this state?
完成的
添加一条评论
添加你的答案
Ulrich 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 267
