跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
iPad Air not turning on after battery replacement
We replaced the battery, as you can see the ipad started to boot but then just turned off, it’s happening repeatedly, I just unplugged and replugged the antennas, LCD and the glass. what do you think is the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Did you use a third-party battery? Apple seems to make our life harder by not supporting third-party replacement parts. I have an iPad Pro 2019 that is now E-waste because the battery wasn’t supported by apple. Did you buy an iFixit battery?
完成的
I purchased and installed an iFixit battery on my iPad Air. It rebooted and operated but the battery charger is not recognized and the device will not recharge.
完成的
添加一条评论
2个答案
已选择的解决方案
The iPad Air supports third-party batteries without issues. The question is if the replacement battery is good or not. However, I have to say that the red flash is quite worrisome. This is a symptom we’ll often see with deeper, logic board related issues, specifically the NAND.
So take a step back, double check your work, look for any damage to the flexes, connectors or the surrounding area on the logic board. I would also re-install the original battery (assuming it was good enough to boot the device prior to replacement) to see if you have the same symptoms. If the original battery allows the iPad to boot properly, then consider the replacement battery to be either bad or deeply uncharged (in which case you can let it charge over night). If the original battery no longer boots the device properly, then you probably damaged something during the repair.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Something worth looking into is potential damage to the pins on the battery connector, not necessarily a smoking gun but something I’ve seen damaged on battery repair before. if it’s alright then I’d say the main culprit would be a chip on the board however I’m not 100% sure on this model of iPad, this doesn’t look like an issue with the battery replacement being subpar however; I’d expect that to show different symptoms like not holding charges well or boot looping (I would however say it is possible if the battery was more or less completely nonfunctional).
这个答案有帮助吗?
得分 1
1条评论:
Does anybody have a picture of what the battery connector on the logic board is supposed to look like? I'm curious if perhaps I've damaged a pin.
完成的
添加一条评论
添加你的答案
חיים גולדפרב 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 3,842
